Old 01-12-2017, 04:46 AM
A98Coupe's Avatar
A98Coupe A98Coupe is offline
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Kevin,
Don't use Blue Hylomar - it is rubbish. I use Threebond liquid gasket 1209 (I think) the grey stuff. It is basically the same as the Motorcraft TA-31 mentioned in above posts. Also, I use Evans Waterless coolant in my Shelby FE stroker. This is far superior to water/glycol mix because it drastically reduces system pressure when the engine gets up to temperature - hence no leaks. PM me if you need further info. I'm in UK like you
Regards
Stuart
