Old 01-14-2017, 08:06 AM
patrickt patrickt is offline
Originally Posted by steve meltzer View Post
Thanx again, Patrick. Are you saying to swap the "I" and "A" terminal wires, if the experiment works??
I want both the "A" terminal feed and the "I" terminal feed to be switched power. Your indicator light is in series, possibly with a 15 ohm shunt, on one of those lines, but I wouldn't bet the farm as to which one. But, I think as a test, if you just pull the "A" terminal off, with the key off, for a few minutes and see if the VR cool downs, then we know what the solution is if that works. Then we just tweak your wiring so the implementation of that solution is elegant.
