Old 01-14-2017, 08:30 AM
spdbrake spdbrake is offline
Originally Posted by Scotchman View Post
Will the Carter pump work with a one way line to the carbs ? I do not have a return line to the gas tank.
The Carter will work fine returnless. I used the P4070 (4-6psi) since I use use it to fill the FiTech EFI pressure pump tank.
[ame]https://www.amazon.com/gp/product/B000CIQ5DG/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1[/ame]
The P4600HP is a great pump as well.
[ame]https://www.amazon.com/Carter-P4600HP-Line-Electric-Fuel/dp/B000CIQ5EA/ref=sr_1_1?s=automotive&ie=UTF8&qid=1484411038&sr= 1-1&keywords=4600+pump[/ame]
Since its vane type impeller with an internal bypass regulator it won't struggle when deadheaded.
The Carter works great. The Holley Red I removed had Flintstone bearings in it, and the Quickfuel pump lasted 4 days. (My fault for not reading the fine print.) "Quikfuel pumps are designed for intermittent duty in drag racing only"
Carter universal pumps are still USA made.
While still a "lift" pump (pushes fuel vs pulling) they do prime themselves well vs some other brands. They should still be installed close to or at tank sump level like other Elec pumps.
