  #21 (permalink)
Old 01-21-2017, 06:37 AM
Tom Cimino's Avatar
Tom Cimino Tom Cimino is offline
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
Use the 390 block and stroke it. You can get 431 ci from a 4.125 stroke, or 445 from a 4.25 stroke (That's with a ,030 cleanup bore). Or, if you want 427 ci, you can use your 352 block, bore it .060 and stroke it to 4.125. The good side is you will get a new crankshaft and way better than stock rods. Also get a copy of Barry Rabotnic's "How to build Max-performance Ford FE Engines. There's a wealth of information in there.
