  #27 (permalink)
Old 01-22-2017, 03:02 AM
120mm's Avatar
120mm 120mm is offline
Cobra Make, Engine: Scratchbuild, 289 FIA Replica
Originally Posted by olddog View Post
This was copied from an article Written by Barry Robotnik - who often visits this site - on the following website DIY Ford - Do It Yourself Ford Projects.
The “Drill Bit Test”
This one test is the single best way to quickly identify an assembled FE block, and credit for it goes to FordFE.com forum member David “Shoe” Schouweiler. You only need the simplest of measuring tools– some drill bits. The following is paraphrased from several of Dave’s responses to block identification questions posed on the forum.
Remove the center freeze plug from the side of the engine block. Using common drill bits, then slip the shank portion of the largest possible bit in between the center cylinder cores through the freeze plug opening. The size of this largest drill bit indicates which water-jacket core was used to cast the block.
If you can only fit a 1/8- or 9/64- inch drill bit shank between the cylinders at the largest gap position on the block, and a 10/64-inch bit doesn’t fit anywhere, then they are 427 water jackets.
406/428/DIF361/DIF391 blocks allow a 13/64-inch drill bit shankto fit into the gap at the largest position.
MCC361FT/MCC391FT blocks (MCC = “mirror 105” marking) allow a 14/64-inch bit to fit between the cores.
Regular 360/390/410 blocks hang around the 17/64- to 19/64-inch water-jacket space at the largest position on the block.
These are only approximations, but tend to be close.
Even if you do have the good jackets, be sure to sonic map the cylinders before boring. If the core has shifted, it could cause problems. It is not at all unusual for FE engines to have considerable core shift. And the oft-raced and abused 427 engines seem to have some of the thinnest cylinders. A block with core shift has cylinders that are thicker on one side and thinner on the other. This can leave the cylinder wall too thin after machining, compromising strength and piston-ring seal.
I literally just read this exact passage from Rabotnick's book. That appears to be a very good reference book; will have to buy a physical copy someday.
I was originally thinking I would not mess with a 352 block and only considered the 390. However with a little reading it appears that Ford cast the 352 and 390 blocks pretty much from the same cores. They just bored the 390 bigger. So most 352 blocks can be bored to the 390" 4.050" size and more. That was news to me. You can through the 360 truck engines into this too.
Again there were some thicker walled 390 blocks that can go to the 428 bore.
Learn something every day. Will keep this nugget of info in mind when I'm selecting a block.
