Old 01-22-2017, 09:02 AM
peterpjb's Avatar
peterpjb peterpjb is offline
I can use Webers, but if I did I would have to run in A Production against big blocks. Therefore, I will be running a Holley double pumper instead so that I am competing against small blocks in B Production. I can use aftermarket heads, as long as they are iron. I will be using Dart Iron Eagle heads.
are you allowed to use roller rockers? and will you go with a k-code hipo block?
