Old 01-22-2017, 07:29 PM
boxhead's Avatar
boxhead boxhead is offline
Yep. I will have a better idea when all the timber is out, but I will find somewhere under the tray to hide them.
Just ordered 20 tie down turn buckles, also a 10t snatch block, so I can run the winch cable down along the tray bed if I manage to get a second Corona on the bed.
My thinking is to make some form of steel raiser that will let me put a Corona on backward, lift the front and put the raisers under the wheels, then get a second Corona on the back with the nose under the first car.
Good work Dave
From the look of the tailgate it should be easy enough to modify to add a door to slide your aluminum ramps underneath. You would want to make some sort of locking mechanism to hook them to the back of the truck too.
Cruising in 5th
