Old 01-25-2017, 11:42 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Default Thoughts on oil pressure vs flow?
I've always wondered what weight of oil would be best in my car. I built my own motor so I can't "just ask the builder what he recommends"...
I've heard some say "Put 10W-30 in everything" and just drive it. That's what I have been using. With my HV pump I get 75 PSI cold idle, 40 PSI hot idle, up to 70 PSI cruise.
I recently came across an article on BITOG that made the remark that no oil at ambient temperatures (anything less that 120 degrees Fahrenheit) is thin enough to flow well - so use the lightest oil made 0W. They also agreed with the 10psi per 1000 rpm rule. So their summary was to use 0W-XX - the XX being whatever weight oil fulfilled the 10per1000 rule with a minimum PSI of 15 at idle when hot. So if I get 70 PSI at 3000 RPM cruise with 0W-40, I should decrease the viscosity to 0W-30 or 0W-20 to get the pressure down. Lower pressure = higher flow. It is the "flow" that provides protection, not the pressure.
Thoughts on this logic?
