Old 01-27-2017, 06:58 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Lots of good info here-------
I once had a cobra guy come to me because his engine also died (quit running) on deceleration-------
So a few basics---is the carb angle flat or tipped down??
Don't lower the primary level-you'll probably need to raise it (maybe)
do you have jet extendors on the primary jets? Secondary? I don't like either way because if you have an issue with fuel leaving the jets you got another problem---
You may just need to do something simple like push in the clutch a little earlier------
try it -------
