  #58 (permalink)
Old 02-06-2017, 09:49 AM
moore_rb's Avatar
moore_rb moore_rb is offline
Cobra Make, Engine: All original, with Chevy engine since 1964
I think my carb issue is all worked out... My secondary float had a tiny little pin hole in the seam right above where the float is soldered to the arm, and the float had gas in it.
So I dried it out, re-soldered the seam over the hole, and kept the float submerged in a pan of water overnight. This morning it popped right to the surface of the water, so I put it all back together, adjusted the float level, and hopefully that will be the end of that...
I'm still going to get that regulator from Scott, and set my pressure down around 7-ish psi, where I prefer it to be...
- Robert
