Old 02-09-2017, 11:29 AM
Cobra #3170 Cobra #3170 is offline
Neutral
Default Valve Train
Well that will sound spectacular. 6500 sounds super, 9000 will be out of this world. What about the other parts? Valve train, etc.
Patrick
Yes using small stem titanium intake and exhaust valves to keep the weight down and a new cam with more exhaust duration and lift, intake lobe will be similar to today's 281@ .050 and 297 @ .050 exhaust both right around .800 lift
a little more aggressive ramp in the middle. Using the very best NASCAR springs this time. The old engine pressures were still at installed levels but thought I should upgrade because of rpm. They are supposed to be better material. Individual roller rockers and .125 wall 3/8" trend push rods. !5 to 1 compression ratio with smaller chamber and a slight pop up on piston. Trying Line to Line coating process on pistons too. The crank should be a work of art according to Kinetics. Head flow is around 380 cfm so that is the limiting factor although we will do some manifold work too. Installing a modern EFI this time with traction control because it is legal now in Goodguys.
