Old 02-10-2017, 09:38 AM
1795's Avatar
1795 1795 is offline
Exactly! A light lift will transfer the weight to the front wheels at turn-in and then you can quickly accelerate. No time wasted going to the brake and should shave off some time. A few of those could end up in a second quicker time.
You will probably have to experiment a little to see how much of a lift is required and for how long. I would suspect that with that setup too much of a lift could risk breaking the rear end loose due to the amount of engine braking combined with the gear ratio.
