Old 02-16-2017, 05:27 PM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
I had that happen once using the plastic alignment tool. It did not center the clutch disc properly. I solved it by hooking up the clutch slave cylinder, and once you are sure the trans splines are into the clutch disc, release the clutch to allow the disc to center, and it will slip right in.
