Old 02-16-2017, 09:17 PM
wkooiman wkooiman is offline
Cobra Make, Engine: Contemporary Classics, red white stripes
Default Not too much
2 Holley 600 vacuum secondary carburetors are not too much. The secondaries only open if they are needed, so it's basically the same as a 600 mechanical secondary with an extra 600cfm if you need it.
That's assuming you have the proper BJ/BK, BC/BD, AC/AD, etc. carburetors and progressive linkage. Ford spent quite a bit of time getting these right. They weren't too much carburetor in the 60's, so why would they be now?
If you aren't using a stock style setup, all bets are off.
I previously ran off-the-shelf 1850s (600cfm) on a 428 that were reworked by QFT. They ran like a dream.
BTW, if you google this subject, you will find several threads. In one thread, someone had lots of problems with 2 390cfm carburetors. Stick with what works, and you'll be happier.
