Old 02-18-2017, 06:43 PM
stephen low's Avatar
stephen low stephen low is offline
Default Next Phases of development
As an ongoing WIP, the next phases of change for the Slow mobile are being progressed.
Most current oddity is getting Marty to finish off my tow bar attachment, so that I can attach a bike rack to carry the road bike. Want this to head down to Torquay in March for the Otway Classic.
I have also ordered Jaguar X308 rear end bits, to enable the rear suspension conversion to vented outboard disc brakes. With this will be a change to good single coil over shocks, a better handbrake set up and then replacement rims and perhaps tyres.
This work coupled with new shockers to front is when I want to get better handling out of the car.
Lastly I have acquired the main component needed to do a mild engine upgrade as pictured.
Will get the ECU piggybacked onto the existing Ford unit to run the E cam I'm to use, plus upgrade to the rockers form 1.6 to 1.7 to suit and probably valve spring enhancement.
Looking like a busy winter rebuild coming soon!
slowy
