  #21 (permalink)
Old 02-23-2017, 07:20 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Mark,
I really don't remember, if it was a B-210 or a B-10. I thought, I remembered B-10 but then Dugly said about the B-210. It doesn't matter, if they didn't change the molds around the window and still can provide the windshield. I looked at there web site and it is worse than terrible for info. It use to be a lot better. If it were me, I would make a stiff cardboard cut out of the windshield that fits your car and when the weather up there improves, make a trip to Shell Valley. Lay it over their windshield an see how they compare. The other alternative is to make a pattern for the windshield and at a set height a pattern for the curve of the windshield and send it to them. I would make the patterns and make the trip and look at the trip as a buying trip for pedals etc. if you plan to build the car. Once you confirm it is the R&D car, then you could pickup the rear window also. The side windows are an easy make later in the build process.
Bill K
