Old 05-21-2002, 03:27 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
the good battery kill switches have four terminals, two battery cable sized, two for the ignition disconnect. If you only disconnect the battery cable, nothing much happens, the alternator keeps feeding amps to the ignition.
most of the switches out there are merely a disconnect, not a "kill switch"
