Old 02-26-2017, 05:10 PM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
"There seems to be some conflicting data there - in one place you said it runs about 6 psi at idle with mechanical or electric pump. And later it idles and cruises at 9 psi. Or did it used to run 6 psi in past years and now it's running 9 psi?
I assume this is a mechanical fuel pressure gage? If your pressure is falling off to 2 - 3 psi at 3000 rpm you either have a mechanical pump going bad or some restriction somewhere. Also, possibly your tank or cap is not venting and it's taking the electric pump to pull it from the tank and push it to the engine. When opening your fuel filter do you notice any pressure being released?"
Sorry about the confusion, but yes it used to fine (except for the drop in fuel pressure, occurring only under load, and solved by kicking on the e-pump....never understood why that has always been that way) meaning running about 6 PSI. The increase to 9 PSI is a new problem and my concern. No, opening the fuel cap doesn't result in an audible sound.
I'll probably have to check the pressure using a fuel gauge but looking for other causes, than a bad gauge. thanx. s
steve meltzer
"I may be wrong, but I'm never in doubt"
