Thread: Missing again
Old 02-27-2017, 06:36 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
When I check the phase, the rotor lines up perfectly on the post. When I rev it up, it moves toward the leading edge. Since I only have about 12 crank degrees of advance, I only have about 6 degrees of distributor advance. Vacuum advance activation doesn't change the relationship of the rotor to cap.
I think I may have found something. While tracing the wires to the 6AL, I found a place where I soldered the wire, then added shrink wrap. It just happened that when I zip-tied everything up under the dash, that solder joint got bent. It may have been a bad joint, failing intermittently causing the miss. It was the small red wire that turns on the 6AL. By the time I got it fixed, it was too late to start it. I will see tomorrow.
