Old 03-01-2017, 04:19 AM
120mm's Avatar
120mm 120mm is offline
Cobra Make, Engine: Scratchbuild, 289 FIA Replica
Originally Posted by Jac Mac View Post
Dont know if this will help, truck trans may have totally different bolt pattern to Top Loader which can be wide or narrow bolt pattern... Bellhousings
That's a nice reference. For transmission types as well as bellhousings.
The truck bell is deeper because it's meant for a New Process transmission, instead of the Toploader.
If you want to go that route, you should be able to find a car bell for a couple hundred bucks. Just remember that the only thing between you and the flywheel is 3/16" of fiberglass and a piece of brittle cast iron though.
I haven't found the $200 car bells. But for a couple hundred bucks extra, I'd be delighted to invest in hardened steel. Question = answered.
