Old 03-02-2017, 03:04 PM
patrickt patrickt is offline
Originally Posted by steve meltzer View Post
When all's said and done, it would cost about $100 to buy the blocking plate and find the right aeroquip or equivalent way to connect the two fuel lines. What pump would you buy? Might even be easier, in some ways, to replace the mechanical pump than to figure out the re-plumb. thanx steve
When I threw out a hundred bucks, I was thinking of this tried and true pump: https://www.summitracing.com/parts/CRT-M6905/ But, others might have other suggestions. And you should also expect somebody to complain about you having a fuel line running in to the dash without an isolator. I've never touched an isolator, so I won't comment on it.
