Old 05-21-2002, 07:09 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
What happens if while hard braking, right as it wants to stall, you rap the throttle. Does it choke on too much gas, or pop from almost dying lean. Holleys usually don't lean out bad, they overflow the vents into the intake and choke themselves out rich. Funny incedent while test driving a 2-4bbl 460....tested the brakes hard coming down from 130mph, stalled the motor, as I coast up to the stopsign, I put it into second gear and drop the clutch to bump start it. Motor does not fire, but flames start shooting out the sidepipes. The Honda I pulled up next to can't believe the 1' flames out the sidepipes by the look on his face. Crank it, but flooded too badly. Hold the gas pedal to the floor and crank it again, when it fired off, four foot flames shot out the sidepipes like a nitroburning dragster. Smiled to the guy in the honda and continued the test drive.
