Old 03-11-2017, 03:39 PM
strictlypersonl strictlypersonl is offline
Originally Posted by wolf k View Post
Also the turn signal lever cancels too easily, have to hold the lever as you turn the wheel so that it doesn't cancel. The lever does latch, but very lightly. It does not take much force to cancel. Is there a fix, or just purchase a new one? Source of these switches for Cobras are all the same?
Thanks, Wolfgang
You can relocate the pins that do the cancelling:
1. Remove the steering wheel.
2. Remove the nut and steering wheel hub
3. There are two roll pins on the backside of the hub that trip the cancelling mechanism. Remove them.
4. Drill two new holes 90 degrees from the original location and install the pins there.
Consequently, when things are put back together, the cancelling pins will be at the top and bottom of the hub. It will take more rotation for the cancelling to take place.
