Old 03-13-2017, 07:18 AM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Gary: Cam is from Comp, spec'd by Barry R, hyd roller , intake dur 234 @050, exh 240.
lobe sep 112.
Numbers are within 10 %
All plugs out, charger on batts, carb wide open
Done while engine still warm.
Should have squirted a little oil in cyls and done over.
When I pull engine I'll be pulling heads for some machine work, so I'll be able to look at cyl walls.
Brent: Was hoping you'd chime in ! If I wasn't pulling the engine anyway, I'd leave it alone.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
