Old 03-13-2017, 04:00 PM
ACHiPo's Avatar
ACHiPo ACHiPo is offline
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Originally Posted by dallas_ View Post
No experience with the Escta V. Is that the correct treadwear rating?
My Escta XS are 180. I thought the V's were around 200.
600 sounds way too hard of a compound for a Cobra.
I agree that 600 sounds crazy-hard, but from the description it sounds like they use engineered sipes to improve traction.
I'm skeptical, which is why I asked. They seem to have good reviews, of course I'm guessing most reviews come from lower profile versions like Ozzie Goat's.
Sidewall Style: Blackwall
Serv. Desc: 96V
UTQG: 600 A A
The Ecsta LX Platinum (KU27) is Kumho's Grand Touring All-Season tire developed to meet the needs of sporty coupe and luxury performance sedan drivers. It is designed to blend responsive handling, long wear and a quiet ride with year-round traction including in light snow.
Kumho molds their advanced all-season tread compound into the Ecsta LX Platinum radial's asymmetric tread design where three different types of sipes are used to enhance all-season traction. Outboard shoulder and intermediate tread block sipes terminate in stress relief dimples to help the sipe openings blend straight-line snow traction with lateral grip. Straight sipes are used for the middle blocks while waffle design sipes are used on the inboard intermediate and shoulder tread blocks to blend dry-road stability with all-season traction. The internal structure of Ecsta LX Platinum tires feature twin steel belts reinforced with spirally wrapped nylon cord on top of a polyester cord casing to combine high-speed durability with ride quality.
SIZE UTQG MAX.LOAD MAX. INFL. PRESS. TREAD DEPTH TIRE WEIGHT
225/60R15 96V SL 600 A A 1,565 lbs. 51 psi 10.5/32" 25 lbs.
RIM WIDTH RANGE MEAS. RIM WIDTH SECT. WIDTH TREAD WIDTH OVERALL DIAM. REVS. PER MILE COO*
6-8" 6.5" 8.8" NA 25.6" 811 KR
Below is a comparison between the Ecsta and BFG. The Ecsta is not outstanding by a long shot, but is quite a bit better than the BFG. The question is how it compares to the Cooper Cobra, Thompson S/T or S/R, and Pirelli P600?
