Old 03-16-2017, 10:15 AM
patrickt patrickt is offline
Originally Posted by Tom Wells View Post
520,
It's on the speedometer cable end outside the trans and is easy to replace.
On ERA cars, it's a medium PITA to get the hold down bolt back in. Here's a pic of mine after I had applied some Torque Seal to it.
if you're going to pull your speedo cable off, you might has well lubricate it if you've seen even a hint of needle bounce. A detailed thread on that can be found here: Lubricating the Smiths Speedometer Cable To Stop Needle Bounce
