  #79 (permalink)
Old 03-19-2017, 11:44 AM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
First of all, i set the floats on the bench, as noted. Followed the instructions, as I have before. To set the floats with the sight plug, the car must be running, right? Or, can you do it just cranking? And yes, fuel was coming from the primary venturis.
When everything is working correctly, and you crank the car, the sound of the starter is more of a staccato "wha-wha-wha", deeper and not all the same pitch, then the engine fires up. Now, my starter makes this high pitched sound that is constant and makes me think the pinion isn't engaging the flywheel. I wacked the starter a few times with a broom handle, but I probably need to get under there and really whack it with a rubber hammer, and probably take it out. Could it be the firewall mounted solenoid (it's only 6 mos old). I think i burned up the starter, fartin' around yesterday. thanx for seeing me through this saga. s
steve meltzer
"I may be wrong, but I'm never in doubt"
