  #26 (permalink)
Old 03-24-2017, 10:39 AM
cycleguy55's Avatar
Originally Posted by kanuck View Post
Do Tunnel Ports and Cammers share the same intake manifold?
Dean
No. They don't interchange with each other, and neither will work with any other FE heads.
The 427 SOHC uses a unique intake that does not at all resemble any other FE part. Closer to a 429/460 intake from an external appearance, the SOHC intake does not have the characteristic FE valve cover rail.
The 427 tunnel-port intakes use a unique bolt pattern and port layout; they do not mount to any of the more common FE wedge heads.
Ford FE Engine Intake Manifolds: The Ultimate Guide
Brian
