Old 03-27-2017, 02:35 PM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
One of the problems with the setup of jag front ended CR's is how close the rack is to the end of the pivot bolt. If it is set with the inner joint right on the pivot it fouls on the bolt. I have a crazy idea to turn the pivot bolt around as the other end has a large flat hex section which should get 15mm more clearance and free me up to space the rack wherever is best.
Also discovered it is currently a little different left to right, with the right side rack mount being about 3mm lower than the left relative to the pivot bolt. Again, worth looking at if your wanting to dial in the front end.
