Thread: Wilwood Pedals
Old 03-27-2017, 05:41 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
Default Wilwood Pedals
So I'm ready to address a very poorly designed pedal box in my EM Cobra. The gas pedal is the only thing that makes sense, clutch and brake are way off.
My thoughts were to just order the predesigned/assembled Wilwood Clutch/Brake set. I do like the idea, however they seem to be designed to use two manual brake masters. No issue with the clutch as I'm already using a 7/8 master, should work fine. Back to the brakes, my Cobra uses a single, power assisted master with a C4 corvette factory brake setup. I'm ok with scrapping the boosted brakes and go to the manual setup, but has anyone gone in this direction? I'm not sure what the factory C4 brakes would like for a master, 3/4, 7/8, maybe 1". Same for both front and rear? Or is there a Wilwood clutch/brake combo that excepts the current single boosted master?
Any guidance is greatly appreciated!
Mike D
Tampa Fl
