Old 03-29-2017, 03:31 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
The rear diff assembly - need to re-position the upper & lower wishbones onto my chassis and narrow the track by 100mm per side in order to fit the rear wheels I have planned, plus provide some nice negative offset on the rear wheels.
Front wheels will have almost zero offset, so I am looking for the complete contrast front to back..
The main thing is to make sure that the rolling diameters are no greater than one and a half percent differential or closer if possible, so that it does not interfere with the traction control.
Axles will require shortening also & considering HICAS on the rear for low speed maneuvering and better turning circle etc..
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
