Old 03-29-2017, 08:27 PM
LMH's Avatar
LMH LMH is offline
Just a little update. Haven't had much time to work on the heater lately but did get to filling some holes. The heater as used in the Prefect, has slots in the front with slide controls to open/close the side doors. The Cobra unit doesn't have these, so the slots need to be filled in.
I'm not sure but I think all British steel is rusted before use! Because of this, I didn't want to get into filling holes with steel. Warping is also an issue as the steel is thin, so I opted to fill using lead.
I spot welded a small piece of sheet steel to act as backing behind each slot.
Leaded using an electric soldering gun.
Filled and ground off. Any small scratches will be filled in with primer and the whole heater block sanded.
One thing though, the original heater isn't perfect by any means and it's my intent to keep the replication that way as well.
Alba gu brąth
