Old 03-30-2017, 10:09 PM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Well, it appears that bad teeth have won the battle. Can't get enough starter bite to start the engine, tho' it sounds very promising for a nanosecond. Put a socket on the crank pulley to change the geometery, but, as noted, not enough meshing to get 'er started for more than a second, then the starter won't engage the ring gear any longer. Set the primary float with the e-pump pulling 5 PSI, and the float is unchanged from before, so that's not the issue. Not sure why, but there's clearly a sl. amount of raw gasoline lying atop the secondary butterflies, tho' the car never started. arggggh. s
steve meltzer
"I may be wrong, but I'm never in doubt"
