Thread: oil level
Old 05-22-2002, 08:18 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I think it's a 5/16" socket, but there are two different size hexes used on fords, always used a deep well. Just the same as the hex on the end of the distributor shaft. You don't need to weld it together. If you want to go that far, just buy the preluber tool for $25 it has a bushing so that it stays aligned in the dist. hole. or get an old distributor shaft and remove the gear.
