Old 04-17-2017, 08:56 AM
tjtibb tjtibb is offline
Cobra Make, Engine: Scratch built Chassis - FFR Body
all good questions.
Backlash and R&P pattern set at installation (have done a few times!)
31 spines as the factory open diff
Axles fully inserted into the diff (as far as I can tell)
I have not put car on floor and moved, only spun the wheels at this point. It is not acting as I though it should, hence the questions.
I think if I put oil in it, place on the ground and roll about, it may change, but not sure.
I may need torque though it to set the clutches?
Trying to avoid pulling it all back out, and still not sure if I can bench test it at that point either.
Anything else to try?
