Old 04-20-2017, 09:17 PM
Cobrakiller's Avatar
Cobrakiller Cobrakiller is offline
Hi Chris, you could use the C6 LS3 Corvette sump to overcome your clearance issue. By raising the engine you will also affect the driveline angles which could cause vibration problems etc. The Corvette sump will give you about 50mm more ground clearance.
