Old 04-21-2017, 07:27 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Default White Pipes - Redux
I finally found out some white paint that works on exhaust. Alvin High Temp Pure white with the gray primer is what I used. I had my pipes media blasted first and then power washed .I primed and let sit for 24 hours. I then applied the paint in two thin coats with about 20 minutes between coats for drying. I then used a friends infrared heater and baked them on each side for about a half hour at 180-190 degrees. The paint has stayed on and has not changed color even at the header collector pipes. This is the first stuff that I have had success. The VHT stuff always yellowed. A picture is shown below.
Phil
