Thread: FE Oil Level
Old 04-23-2017, 05:51 PM
AZMike427's Avatar
AZMike427 AZMike427 is offline
Cobra Make, Engine: Superformance #751- 427FE
Originally Posted by Bob Broberg SPF667 460BB View Post
Mike, wish I knew more but an FE with a full sump and oil cooler could need 12 quarts. Add until it registers full, then run motor till warm, let settle and you'll finally know. If your dipstick is correct you do not have to worry about overfill. If it may not be correct, just add oil to 1 quart down and run, rest, measure. Jeff Classic has a way to eyeball check if your dipstick is marked correctly. How many quarts came out?
AZ Bob
Well I'm kicking myself for not draining into an empty oil container. I did the oil change on my GT500 last weekend into the same 5 gallon container I used to drain the cobra.
Right now I have 11 quarts in it and it's settling.
I'd definitely be interested in Jeff's method to check the dipstick. I believe it's the culprit here and am leaning towards draining all the oil and starting over. I already ordered a new case of oil figuring I'll need it sooner or later. I'm also thinking of adding the dipstick to the passenger side port on the aviaid pan and calibrating it correctly.
Superformance Cobra #751- guardsman blue- 427 FE
2011 GT500- black/black- 700hp
