Old 04-26-2017, 10:30 AM
cycleguy55's Avatar
Originally Posted by mdross1 View Post
Thanks for the input not having any problems especially after hearing from you guys. I will look into another fan controller Brian my sensor is mounted on the radiator. Are you running a fan shroud?
Dual fan setup with what I'd call a semi-shroud - it doesn't fully cover the radiator surface. I suspect the builder used an off-the-shelf setup without regard to closing off the rest of the radiator core. It seems to work well enough - the only time I had any real issues with heating was when the cooling fan relay failed.
Brian
