Old 04-28-2017, 02:55 AM
mdross1's Avatar
mdross1 mdross1 is offline
Originally Posted by Tom Wells View Post
Mike,
I run the 180 and it seems fine. Running temp is in the 190-210 range. I use a 16lb cap.
What temp the engine needs to run correctly seems to be a 6-beer discussion, so just my opinion that the 190-210 range is fine.
I do put a small hole in the flange of the thermostat to allow air to escape even if it isn't open. 3/32 is probably OK.
If you want the fan(s) to run less you might consider adjusting the on-off temps a bit. Mine come on at around 190 and off about 180.
Tom
Tom
While the manifold is off feel the need to try something new. The hole in the thermostat must help burping air out of the system I assume. With yours and Brians info looks like I'm in pretty good shape.
Mike
