Old 05-04-2017, 09:09 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Yes, they are cramped partially because the pedals come up through the floor. It is something you get used to, but if you drive it for a long time, it is a little hard to stretch. Somebody was working on hanging the pedals from the top. Neat idea, but probably a lot of work. The up side is the can handles really nice because it is roughly 49/51 balance. With the 10" wide front tires and manual steering. It still steers pretty easy.
I have never heard of a Mustang ll front end upgrade. I suppose you could do it, but unless you are good at fabrication, you might have a hard time. I have seen a lot of Arntz and Butler cars and they all had MG front ends. There is a company called FAST in Michigan that has a tube upgrade with Wilwood brakes. Easily bolts in p,ace. They are not real cheap, but they work great with coilover. I have that upgrade in mine. I think Unique Cobras also have an upgrade as they originally used MG front suspension. I called them, but they were the same price as FAST and the FAST was a bolt in and theirs required welding etc.
Mine has a LS3 now with a T56. It has 575 hp with 3.70 gears and it runs great. The frame/ body in these cars are really strong. If I had to guess, yours is probably a Tupe 3.
