Old 05-07-2017, 11:05 AM
69boss429 69boss429 is offline
I have found the original paper gaskets work best so if you have them try them.
I can't see where you could use teflon tape to help as it's not at the threads that it is leaking, is it ?
It's past the screw head, so tighten evenly on all 4 corners
You might try carefully coating the mating surface where the screw gasket is with some Rite Stuff gasket compound. Let it dry for 24 hrs before filling bowls
I have had issues like you describe in the past and these fixes worked for me
