Old 05-08-2017, 07:11 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Shootnride View Post
I had one Holley that had a slightly warped metering block. This can be checked on a surface plate or with a precision straight edge and feeler gauges. A friend of mine that does a lot of work on Holleys said that this is a fairly common problem, so it may be worth checking.
Ted
The benefit of the UV dye is that I can tell where the leak is coming from. Definitely the bowl screws.
www.partskeeper.com
