Old 05-10-2017, 05:12 PM
CBattaglia's Avatar
CBattaglia CBattaglia is offline
Cobra Make, Engine: Gary Edwards Racing 460
Originally Posted by Tom Wells View Post
Mike,
I run the 180 and it seems fine. Running temp is in the 190-210 range. I use a 16lb cap.
What temp the engine needs to run correctly seems to be a 6-beer discussion, so just my opinion that the 190-210 range is fine.
I do put a small hole in the flange of the thermostat to allow air to escape even if it isn't open. 3/32 is probably OK.
If you want the fan(s) to run less you might consider adjusting the on-off temps a bit. Mine come on at around 190 and off about 180.
Tom
Engine oil optimum temp and acceptable temp range??
Beer open... go! I have been doing a lot of reading and I can't get a straight answer.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
