Old 05-22-2002, 11:23 PM
Snake Snake is offline
Post DV
Hey DV! Got the brake pedal switch...kinda a weard looking thing...can you explain how to mount it.
Also I find that the passanger door looks to be twisted...what I mean is when the door is flush to the bottom of the body...it is not flush at the top towards the back end of the door and looking threw the rear fender well were the bear claw would go...the hole were the door post hole is in the door....doesn't line up...looks to be a 1/4 of an inch off. Does this happen often? If I get the door to be flush at both ends...I will need about 1/4 of an inch on the side and on the top to build up the door for it to look right. Have you had this problem before and what is the best root to take.
Thanks.
Snake.
