Old 05-22-2017, 09:25 AM
CNGreen's Avatar
CNGreen CNGreen is offline
Cobra Make, Engine: FFR MKIII, FMS BOSS 302 "B" cam
Originally Posted by MAStuart View Post
Do Trigo FIA wheels that fit original CSX cars have different thickness of the wheel center hubs? Front 7 1/2 rears 9 1/2. I am not asking about back spacing. I am concerned about the thread engagement of the Knock off threads. I only have a front wheel and the thread engagement seems fine on the front hubs. But putting the front wheel on the rear hubs I only have 4 turns of thread engagement.
Mark
My Trigos are not FIA's but yes, it seems the rears may be thicker because the do not seat as low as the fronts. I've never measured them but the eyeball test says there must be a difference there.
I have 12k on mine over 10 years so it hasn't been an issue for me. Just make sure you use liberal anti seize, whack the snot out of the spinner (with the wheel on the ground. Pounding on the suspension at full droop no bueno) and use safety wire.
HTH,
