Old 05-23-2002, 06:32 AM
Frank Coppola's Avatar
Frank Coppola Frank Coppola is offline
Steve,
Thanks for the info and your email. Your suggestion:
"you can do the bolting (to the floor) after its all in place.
I had to move mine around a bit for the best fit.
A little trick to move it. Cut up a few small pieces of pvc pipe
3/4 to 1in is fine. Then use a jack to lift the post then slip the pipe
to
the front of the plate in the direction you need to go. do this on all 4
corners.
you can roll the whole thing with a pinky. well almost. lol."
-is excellent! I'm going to pick it up and assemble it on June 8th and will let you know how it went.
Frank Coppola
___________________________________
"Gunga Galunga... gunga, gunga-galunga."
