Old 05-26-2017, 05:47 AM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Originally Posted by Cobra #3170 View Post
We are planning on going but will be a completely untested set up. New shock pistons and engine with much lighter crank. We will have to try and tune it there. There are no events to run so I will break in the new diff on the subdivision roads and hope it all works out. I got oil pressure today spinning the dry sump pump, radiator is in, brakes installed, steering rack tied down, all fuel lines reconnected. Power steering pump, alternator and wiring tomorrow.
Sounds like you're making good progress. Look forward to seeing you run with the new engine. It should be impressive, the old one sure was.
Ted
