Old 05-23-2002, 07:58 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The tubes which stick up into the aircleaner about a 1/2" and are usually cut off at a 45 degree angle, those are the bowl vents. You need to get the white plastic baffles for those passages. The white plastic baffle is the "whistle" I was referring to. It's about 1 1/2" long, 1/4" thick plastic that's hollow in the inside. It is inside the fuel bowl not within the vent tube itself. Actually mounts to the metering block, and sticks out horizontal, above the float. It is a factory part and I din't understand why Holley doesn't put them in every carb. Will be entirely unnoticable, except the lack of fuel slosh in corners and braking.
