Old 06-01-2017, 03:53 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by dcdoug View Post
Will not be driven hard IF I inspect the bearings and then give this a try. I'll probably send the oil in for analysis too. I should of done all of this last Oct...lesson learned.
Or I could just drive it 500 miles to Lykins Motorsport in Kentucky
I'm no expert, but I assume something will go wrong at idle almost as much as DumbDumb's comment of 6,000 RPM. You seem to know what you're doing. Follow the advice of checking everything you can, both under the valve cover and with the oil pan removed. And as Brent said, assuming all looks good and tight, change the oil and filter and drive it. Slowly at first and as your confidence grows after a whole lot of miles, then increase the RPMs.
Hopefully, everything is OK and the known remains an unknown. Or as Patrick's idol once said:
"As we know, there are known knowns; there are things we know we know. We also know there are known unknowns; that is to say we know there are some things we do not know. But there are also unknown unknowns—the ones we don’t know we don’t know."
I think these particles in the oil were "unknown unknowns" and now are "known unknowns."
